Error -375006 unflatten from JSON with a list of variables
Hello everyone. I'm working on LABVIEW NXG and I'm trying to open a JSON that has an array with a list of variables. The JSON has the "type and defaults" terminal that is required to wire but I don't know what I have to write/place there to be able to read the list of variables.
I already try to put an array constant and inside a string constant since is text what I'm expecting, to me, it makes logic but it's not working. Can someone be so kind helping me with this?
Thx in advance!
(1,293 Views)
Accepted by topic author Ghdez
What kind of JSON data are you expecting? You need to model a LabVIEW cluster that corresponds to the expected data and wire it to the type and defaults terminal.
(1,240 Views)
In addition to what @cordm said, if you are getting started with LabVIEW NXG in order to use the Web Module I'd recommend looking into the newer G Web Development Software.
G Web Development Software is the successor to LabVIEW NXG Web Module and has the latest updates available. A good getting started guide is How to Build a Web UI for Your LabVIEW-Based Test System.
Milan
(1,220 Views)
I was expecting an array with a list of variables. And thank you for your comment, I already fix the problem I was facing.
Here is how I did it.
(1,204 Views)
Thank you @MilanR for your kindly advice. I'm currently using NXG because that's the one my university has credentials. Maybe later they will get the G Web.
(1,202 Views)
