05-28-2019 04:48 AM
I am brand new to labview so sorry if this is a stupid question, but I am attempting to use my rio to control a I2C device, but I am running into a problem. Using the code attached, I get error -363011 at error 3 onwards, which says:
"LabVIEW myRIO: A No Acknowledge (NAK) bit was received from the slave device after the last address transmission."
I don't understand why I am not getting an acknowledgment signal, which I assume has something to do with the code but I do not understand labview enough to know what I have done wrong. I have included the I2C protocol I am trying to code
Andrew
05-29-2019 07:20 AM
Hey Andrew,
Would you be so kind to attach you actual VI? It's easier to go from there to help you. Also, can you share a link to the documentation of your I2C device? Or, if it is not public, at least the name+model?
Looking at your screenshot, I had several ideas on what could go wrong (cannot verify any without your hardware, sorry):
05-29-2019 10:51 AM
Thanks for the reply. The screen shot of the Vi wasn't the actual version I was running as I was trying to play around with the register address to get it to work and screenshotted a incorrect version. The one byte version in on the attached Vi. This should give a one byte register address, but when used still brings up the same issue at error 3.
I was attempting to use the write function as I thought that was the correct way to write the register address for the multi-byte read? I have attached the datasheet for the device.
Thanks for your help,
Andrew
05-29-2019 10:52 AM
Sorry I don't think the Vi Attached
