Error -2147312566:: Excel 2013, LV2015
Yep, I found it out...I was not aware we can "repair" office ... I did it and it works, thank you very much
Message 11 of 15
(1,253 Views)
hi fabbro12,
i just about wanted to write you something... but you have solved the issue already. Glad to hear that!
Rajamodol
Message 12 of 15
(1,250 Views)
Wanted to chime in and update, that with Win7 64-bit and Office365 [Latest version of Office]
That 'Repair (Quick Repair) did work to alleviate this error....
Message 13 of 15
(1,123 Views)
Hi folks. I had this same error code but none of the fixes here worked. In case it might help anybody else, this is what I did:
In my case, the computer that the executable was deployed to had originally had Office 2016 installed which was removed and replaced with Office 2007 (because that was IT's solution to our request for a perpetual Excel license). Repair didn't do anything and I could never figure out exactly which Activex component would need to be registered according to the fix stated here, so both those paths wound up being dead ends.
Turns out this fix for a completely different error code held the solution. It appears the Office 2016 uninstall left a particular registry behind and every time LabVIEW tried to find Excel._Application, it was looking for it in the old Excel 2016 location (the 1.9 subkey). After removing the 1.9 subkey from the registry, it worked fine.
Message 14 of 15
(980 Views)
I just want you to know that here in 2025 your fix is still relevant and saving my bacon! Thank you so much for the hard work! I just ended up getting this error with 365 updating itself and having an issue. Thank you so much!
Message 15 of 15
(88 Views)
