10-23-2019 02:05 AM - edited 10-23-2019 02:11 AM
I got this error with CANopen Interface 658001. What is it?
10-23-2019 02:39 AM
Hi Zhang,
again you forgot to attach your VI and to mention the type of hardware and software you are using! I guess it is related to this thread!?
Did you read the error message? Did you follow its suggestion?
10-23-2019 03:47 AM
| −2147136858 | The property value or the parameter value is not valid. Ensure the property value or the parameter value is in the valid range. |
The error with 2147136858 should check the value by setting parameters. I have checked them.
You can see the picture. The error began from this Flat Sequence structure. I guess it has some parameter with this structure conflict.
Thanks!
10-23-2019 03:51 AM - edited 10-23-2019 03:53 AM
Hi Zhang,
The error already comes out of "CANopen Interface Create"! (Which you should be able to notice when using Highlight Execution debugging…)
There is a coercion dot at one parameter of that function: what happens when you remove that coercion dot?
