Error 20023 "The following conditions must be met: 0 < f_low <= f_high <= fs/2."
Message 11 of 23
(3,202 Views)
That's the same VI as message #1 and doesn't include your attempt at turning the data into a waveform.
Reread the last few messages, particularly mine about you dT values and the filter frequencies.
Message 12 of 23
(3,198 Views)
First of all, replace your two filters with a single bandpass. No need to clutter the diagram.
You are only reading 10 samples, so the information content is low and filtering such a small part seems pointless. Get rid of all the express VIs and just use one of the ptbypt filters followed by the ptbypt peak detector that gives you a true whenever a peak is encountered. See how often these occur and you got your desired information.
Do you have some typical (simulated or real) data?
Message 13 of 23
(3,196 Views)
Oh sorry my bad. Yes i read your message very carefully and did what you said. Now the original error doesnt pop up except a new error at peak detection vi. ive attached the edited vi. thanks
Message 14 of 23
(3,193 Views)
What does the new error say?  I can't run your VI without your subVI's.
Message 15 of 23
(3,190 Views)
Yes im getting the signal from a pulse sensor through arduino to the pc
Message 16 of 23
(3,189 Views)
Yes, we figured that out long ago. Are you responding to any particular posts here?
Message 17 of 23
(3,187 Views)
At the peak detection vi it states Error 20013 ... Analysis: The widith must meet 0<widith<samples
Message 18 of 23
(3,186 Views)
Yes yours and another person
Message 19 of 23
(3,182 Views)
Accepted by derek.s
On the first iteration, your collector has only 10 samples, but your width is 15.
Message 20 of 23
(3,181 Views)
