01-28-2011 12:26 PM
I get the following error when running my VI, says device identifier is invalid (ERROR -200220) and I was wondering how to fix this..
01-28-2011 12:28 PM
this keeps repeating for others such as AO Voltage and I have to end task to shut down labview.
01-28-2011 12:40 PM
would it be that my chasis is unidentified? Im confused as to which to choose? Im using NI cDAQ-9172
02-01-2011 09:41 AM
Hi there,
It sounds like this might just be an issue with using the wrong device name for your cDAQ module. Make sure that you are using the same alias name that you have configured in MAX for your device. This KnowledgeBase might
help you: Why do I Receive Error Code -200220 When Running a Data Acquisition Program?
02-02-2011 03:30 PM
also get -200099 error codes after this
02-03-2011 10:29 AM
You get this error after doing what exactly?
02-04-2011 11:57 AM
fter trying to run my labview VI...I have to task manager as the errors keep projecting
