Error -200220 occurred at DAQmx Create Channel (AI-Voltage-Basic).vi:1
Possible reason(s):
Measurements: Device identifier is invalid.
Device Specified: Dev2
Task Name: _unnamedTask<2>
i need help here
i have a 6009 USB
and at MAX it is called DEV 1
and in the program is appearing this error =x
give me some feedback please!
(5,174 Views)
So you want to acquire data at your DEV1, but in LabVIEW you selected a Dev2.
Either you change the alias of your USB6008 in MAX to Dev2 or you select DEV1 in LabVIEW.
Christian
(5,172 Views)
ok the first problem is solved...
but now in the another program
its appearing:
Error 1 occurred at Read File+ (string): Read File
Possible reason(s):
LabVIEW:  An input parameter is invalid. For example if the input is a path, the path might contain a character not allowed by the OS such as ? or @.
NI-488:  Command requires GPIB Controller to be Controller in Charge.
(5,170 Views)
Obviously, it has nothing to do with NI-488 so check the path that you are providing.
(5,167 Views)
