Error 200088 using the DAQmx for I/O test (NI USB 6008)
Gerd,
How did you solve that problem? I am doing same loop test and have same error 200088. Tried everything mentione here but still having same error
Help much appreciated.
Message 11 of 14
(479 Views)
Gerd,
Message 12 of 14
(479 Views)
Have you tried opening up any of the example VI's that come with DAQmx? You can get to them by going to Help>>Find Examples, in the bottom right of the NI Example Finder you can add the USB-6008 to your hardware. Then check Limit Results to Hardware. This will give you only the examples for that device.
Jonathan L.
Technical Support Senior Group Manager
Message 13 of 14
(450 Views)
You are going to have to show your VI (and provide the version of LabVIEW you are using). The VI attached to the video in the first post does work so you must have done something wrong if you created your own version.
Message 14 of 14
(440 Views)
