12-24-2011 09:15 AM
Labview 8.5 / DAQmX 9.3 / USB-6211
I didn't want to post this without trying everything I could think of but after a week I'm out of ideas.
I create 2 tasks in the config subvi, analog read and digital read. When I run the main vi (Digital Read Problem), it runs with no error until I invoke the config.vi. Then it throws an error -00088 (task invalid or unassigned). I have run it with the tracer on (light bulb) and the digital read (where I indicated in the block diag) is the area of the problem. Error is 'OK' going in, '-200088' coming out. I defined the task before it is called but it seems to think I didn't. I am sure that I've made a workflow mistake but I just can't find it. Any ideas???
BTW There is a RT menu file with this project that this board won't let me upload. I hope the vi can run without it as it
is a menu choice that invokes the config.vi
Solved! Go to Solution.
12-24-2011 09:24 AM
Well.... my vi does not work without the .rtm file and NI won't let me attach it so I am trying to get ctreative and change the extension to .txt.
Change the extension of Digital Read Problem.txt back to .rtm and it should (might) work.
12-24-2011 11:23 AM
One thing that I immedaitely see is that your event structure in the subVI makes the task null because you have 'Use Default if Unwired'.
12-24-2011 12:45 PM
Yes. Stupid mistake. Actually there was no reason for those 2 cases to be unwired so I wired them. I wasn't looking at any cases except the config-done. Sometimes you stare at something for such a long time that you just get tunnel vision and can't look at the big picture. Thanks much, Dennis & Merry Christmas.
