10-30-2012 10:09 AM
Sirs,
I am work on strain gauge matters measurements using a strain 120 Ohm connected to the NI9944 to build the quarter bridge that goes inside the 9237.
I am using:
NI cDAQ 9178
NI 9273
NI 9944
Labview 9.0
I am using the same program that is given in here : https://decibel.ni.com/content/docs/DOC-11148 with internal excitation 2.5 V, gauge factor 2 (default).
internal shunt resistance 100 kohms; shunt location R3 (default setting). Have selected "Do offset null" and "Do shunt cal"
Error -200077 occurred at DAQmx Perform Shunt Calibration
(Strain).vi:1 Possible reason(s):
Measurements: Requested value is not a supported value for
this property.
Property: AI.Bridge.ShuntCal.GainAdjust
You Have Requested: -61.980405e3
Valid Values Begin with: 500.0e-3
Valid Values End with: 1.500000
If "Do shunt cal" green button not selected, no error.
Also If i use DAQ Assistance which work just fine with the calibration for the same connection of strain gauge , Ni9237, 9945.
Any ideas?
Please help me out here.
10-30-2012 11:40 AM
@shivp wrote:
Sirs,
I am using:
NI cDAQ 9178
NI 9273
NI 9944
Labview 9.0
(Strain).vi:1 Possible reason(s):Measurements: Requested value is not a supported value for
this property.Property: AI.Bridge.ShuntCal.GainAdjust
Any ideas?
Negative number?
Ben
10-30-2012 12:29 PM
Ben
yes it's give negative number with error.
some time it also give positive number here.
I have also attached the pic of an error here.
plz help me out here.
thank you
