04-15-2013 03:29 PM
I have a program I developed in LV 2009 in 2009 and now I am updating it. I accidently opened it up in 2010 and saved it. There are Microsoft office tools that were built into LV 2009 that are removed in 2010 that I had used in my program. So I had to save as previous version (2009). After everything worked and I could run the code and compile I continued developing. At one point I tried to compile and got an Error.
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the following information as a reference:
Error 1430 occurred at Create Folder in Create Directory Recursive.vi->AB_Destination.lvclass:Create_Destination.vi->AB_Build.lvclass:Create_Destinations.vi->AB_Application.lvclass:Create_Destinations.vi->AB_Build.lvclass:Build.vi->AB_Application.lvclass:Build.vi->AB_EXE.lvclass:Build.vi->AB_Build.lvclass:Build_from_Wizard.vi->AB_UI_Frmwk_Build.lvclass:Build.vi->AB_UI_FRAMEWORK.vi->AB_Item_OnDoProperties.vi->AB_Item_OnDoProperties.vi.ProxyCaller
Possible reason(s):
LabVIEW: The path is empty or relative. You must use an absolute path.
<Not A Path>
I have now figured out that if I add a new VI to the program, it gives this error. If I remove the VI, it compiles with no errors. If I add a blank VI with no code, it gives the error. I have worked as far as I could without adding a VI but now i need a pop up window and need to the VI. The code is too large to fit the max 6MB requirements.
Matt
04-16-2013 12:58 PM
Hi mattyk,
When you say compile, do you mean press the run button? When exactly does this error show up?
I suggest you try copying all of your VIs into a new project, and try running the new project. It sounds like your project may have been corrupted in the process of upgrading and re-saving to a previous version.
I hope this helps! Regards,
04-19-2013 10:50 AM
Thanks for the help. It was as easy as doing a file "save as" in the project and resaving the project as a different name.
