01-21-2014 11:33 AM
Hello everybody, !
I'm trying to install LV 2013 64bit on W7 but I have directly this error :
see file attached picture A
Therfore I test the protrocol define here
and just after modifying the parent folder permission access I have this message :
see file attached picture B
I keep on and clik on the child folder and I have :
see file attached picture C
and I right clik on these same folder to open the permission acces and I have a beautiful windows sentence :
see file attached picture D
" You have not the permission to display the permission settings but you can modify these permissions"
But how ?
So I try to add a group name as SYSTEM with full optiion but it is still forbiden to modify the child key as the picture shown :
see file attached picture E
Have you some suggestion ?
PS: I have instal and uninstall 32bits version before on this PC. After uninstalling these version I have clean the register (CCleaner) and no National Instrument instance have found. So It seems to be ok no ?
Thank you !
All the best,
Solved! Go to Solution.
01-23-2014 03:27 AM - edited 01-23-2014 03:27 AM
sorry wrong post.
01-23-2014 06:46 AM
system restored, install ok now...
