09-29-2010 08:35 AM
I am using LabView 2009 to control a research system contains Lakeshore 331S and Keithely 2425, it was work probably , but recently I am receivng an error message:
Error 14 ocurred at GBIB write, LabView cant add resource
09-29-2010 09:53 AM
Not really clear: was it working, and has suddenly stopped?
Did you make any HW/SW modification on your system?
09-29-2010 08:18 PM
Error 14 does not mean "LabVIEW cannot add resource" in your case. You should have nticed that it says "possible reason(s)" and it says "NI-488: GPIB bus error." Check your cables and try with a different set of instruments.
09-30-2010 04:11 AM
you are right , the message says: possible reason(s)" and it says "NI-488: GPIB bus error."
I have checked the cables and I examined the connections with sending a command, it was received successfully by Lackeshore 331S through (measurement and automation explorer, version 4.6.1).
10-01-2010 01:37 PM
Hello baalbiss,
Which version of the 488.2 driver do you have installed? Just to confirm, you are able to communicate with the instrument through MAX, but not through LabVIEW? Did you recently upgrade to LabVIEW 2009?
10-03-2010 05:47 AM
Hi Ryan T,
The version is 4.6.1
I am able to communicate with the instrument through MAX, but not through LabVIEW ,also I created execution files for the same VI's and they communicate with the instruments but with other PC
If you could send to me how I can make the upgrade to labview 2009.
10-03-2010 06:01 AM
Hi
The version of 488.2 software is 2.71
thanks
10-03-2010 04:27 PM
The error often indicates a hardware problem. Have you tried replacing the cables or only having a single instrument connected? You say you communicated to the Lakeshore but don't mention the Keithley. Exactly where in your code does the error occur? During a write? During a read? For which instrument?
10-04-2010 01:52 AM
Hi
The error occurred at GPIB write. The problem with the both instrument (Keithley and Lakeshore) connected at the same time with the PC, about the cables I have checked them by testing the connection with MAX, and sending commands through it.
10-04-2010 04:44 PM
Hi baalbiss,
What GPIB address are you sending into the GPIB Write function?
