Error -1074395720 occurred at IMAQ Get LCD ROI
Hi guys,
I'm trying to get more robust my vi, that I use to read sequence of letter on a LED 7 segment display.
Infact the position of the seven segment in not always ripetitive, matter of a mm.
But the final routine that I use, IMAQ Read LCD, is very fussy about giving back the decimal point, if ROI is not very close to the right.
So I would like to use IMAQ Get LCD ROI, hoping it could give me a perfect ROI for IMAQ Read LCD.
(I use IMAQ Read LCD instead of IMAQ Read Single digit, because I never had the decimal point reading from "Read Single".)
But IMAQ get LCD ROI refuses to give me any good result, always Error -1074395720.
Could someone link me any example using it?
I'm also looking for a new version of "IMAQ Vision for LabVIEW - User Manual" since the last I fund is 2004 edition and only indicate that those functions exists but not more.
I've some double on the input I must give to this VI.
I'm pretty sure to give it the right image with the right global rectangle, because I add images when the LED start, and it turns on in turn each segment. This is the result:
(3,586 Views)
Hello PincoG,
maybe this document can help you:
http://digital.ni.com/public.nsf/allkb/0F464CE7C1D1D968862574EF004FCC7D
(3,549 Views)
