08-22-2019 03:37 PM
I'm upgrading existing LabVIEW 2008 application to LabVIEW 2018 and using a new NI USB-8502.
Original code was written to use NI-CAN and I would like to keep using NI-CAN instead of re-writing the code to use NI-XNET.
I've installed NI-XNET Compatibility Library for NI-CAN.
When the ncConfigCANObj.vi is called, I get the error :
Error -1074388560 occurred at NI-CAN Configure
CAN Object
(ncConfigCANObj.vi)
Possible reason(s):
NI-CAN: (Hex 0xBFF621B0) The feature specified has a design under NI-CAN which cannot be made compatible with NI-XNET CAN hardware.
I've attached the code (LV 2018) and the screenshot of the block diagram. Do you know what could be the issue here?
Thanks in advance.
08-26-2019 08:49 AM
You may get more responses if you repost this in the Automotive and Embedded Networks forum here: https://forums.ni.com/t5/Automotive-and-Embedded-Networks/bd-p/30
The people that look at those forums are generally more familiar with CAN and the NI CAN/XNET drivers.
08-26-2019 09:30 AM
It looks like it's the Transmit By Response = TRUE, check the NI-CAN manual Appendix F
