09-05-2019 01:40 PM
I have a cRIO with a serial port module installed which works correctly the first time the serial port is configured after startup. But if the application is stopped and started again an error occurs when "VISA Configure Serial port.vi" is called (the input parameters are the same all the time and the selected port appears in MAX as expected), error description is "VISA: (Hex0xBFFF0011) Insufficient location information or the device or resource is not present in the system." To get the serial port working the cRIO must be rebooted and then it works the first time again.
I've found this knowledge article (https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P9IASA0) about this error but didn't find any of the issues that was listed there.
What else could be the problem here? I'm currently running in development mode (LV2017), and maybe this is not a problem when deploying an exe to the target, but it is kind of annoying not to be able to restart the application without rebooting the cRIO during development.
09-05-2019 02:45 PM
Try;
Tools >>> Options >>> Environment
and mark the property "Automatically close VISA Sessions".
Your code should be closing the port when it is done as well.
Ben
09-05-2019 02:59 PM
I'll try the environment setting and see if this will have any effect. Is this setting applicable to cRIO targets as well?
The ports are already closed in the code.
09-10-2019 03:16 AM
The "Automatically close VISA Sessions" setting didn't have any effect, it's the same error. Any more ideas?
09-10-2019 05:45 AM
Hello hunkel,
Have you see the LabVIEW example of the NI 9870 module??
If not you can find it:
LabVIEW => Help=> Find Examples => search "NI 9870" and select "NI-987x serial Loopback.lvproj".
I wish it can help you.
09-10-2019 07:28 AM
Yes, found it but that example is using FPGA. I'm using the module in Scan mode.
