Error -1073807339 occurred at VISA Read in basic_gpib_write_and_read.vi
I have a Norma D6000 and my computer install the Labview 8.6 , I have all the drivers and When I use the samples ,
when i type in the command "*IDN?" it reply the "NORMA  ,A4603305/D6200"
so the device works,but everytime i give the command "RED?" I try to read out the data , it comes back the timeout expired before excution complete error.
I'm confused , I increase the timeout value to 10000000 and decline the read buffer of READ block to just 1 , it is still the same.
anyone can help me to read the data out of my machine?
(3,449 Views)
it's GPIB source and I use VISA to connect it
(3,446 Views)
Are you using these drivers? Not sure if Norma and LEM are the same.
(3,424 Views)
See whether this kb helps
and this
Message Edited by muks on 04-28-2010 07:41 PM
(3,422 Views)
Those apply for a serial connection. The OP has a GPIB connection. Big difference.
(3,418 Views)
