Error -1073807339 occurred at VISA Read in Keithley 27XX.lvlib:Error Query.vi-
Dear all,
I use Keithley 2700 with serial communication. If i loose communication with instrument after hours of data acquisition I must restart computer.
What does not work for me:
- reconfiguring communication runtime,
- reset keithley (power off/on),
- close and start labview application,
- change of communication cable from serial to USB cable
- software updates: NI 488.2 16.0 to 19.5, NI Serial 17.5 to 19.5, Installed: Keithley I/O Layer version C10
This issue with communication still occurs even after NI software updates.
I get the following error:
'Error -1073807339 occurred at VISA Read in Keithley 27XX.lvlib:Error Query.vi->Keithley 27XX.lvlib:Error Query (Multiple).vi->Keithley 27XX.lvlib:Configure Scan.vi->SUB = KEITHLEY INIT.vi->MAIN = test.vi'
Could anyone please share ideas to fix this issue? What can this issue be related to?
Kind regards,
Balázs
(2,830 Views)
Is it possible, that data transfer buffer is overloaded?
(2,761 Views)
It would help to see your code.  If possible reduce the code to a simple test case.  That way we can spot potential errors.
Without seeing the code, I can say that I've had issues with USB-serial converters and also with USB power settings (Windows selective suspend) dropping out and causing problem like yours.  Power settings help, see here - https://www.windowscentral.com/how-prevent-windows-10-turning-usb-devices
When selective suspend happens the software still has an open handle to the instrument but its no longer valid, and only a restart fixes things.
For long term measurements use LAN or GPIB and avoid USB.  I've gone back to PCIe-GPIB cards over USB-GPIB adaptors and those fixed the problems I was seeing.
Hope that helps.
Craig
(2,751 Views)
Hi Craig,
You can find my VI as attachement.
Kind regards,
Balázs
(2,731 Views)
If any error triggers a reset then your code needs to a shift register so that the VISA resource ID gets passed back to the read inside while loop catches the new ID.  Wires on one right side of a loop only pass values back to the left side of a loop if you use a shift register. Like so ..
This still might not be enough to solve your problem, but at least if its possible to restart communications then there's a chance it would work.
Craig
(2,717 Views)
