01-12-2007 02:34 AM
So after several hours of tests, It's still working wihtout error!!!!
As a conclusion => NI-SERIAL RT 3.1 is bugged (in my case!!))
01-15-2007 02:32 PM
Hi julesjay,
So you’re getting the error when you have either NI-Serial RT ver. 2.5.6 or 3.1, but not with ver. 3.0, correct? And also just as clarification, if you use the DMA FIFO between FPGA and RT on the system with NI-Serial RT ver. 2.5.6 or 3.1 you do not get the VISA read error? From what I have seen this has not been a documented bug at this point. You also mentioned that the error occurs intermittently. How frequently did it occur and did there seem to be any trend along these lines that you could see? Thanks!
01-16-2007 07:33 AM
01-17-2007 07:56 PM
01-18-2007 03:02 AM
Hi Anna,
I don't understand what's exactly the question.
I don't realize DMA transfert with RS232. I'm using RS232 to communicate with an emitter. MY DMA FIFO is from FPGA to host.
VISA parameters are 9600 baud and buffer size 256 ( if think; I don't remenber precisely). But I've also tried to change buffer size with no result.
01-18-2007 09:19 PM
Hi julesjay,
It looks like what we may be seeing here is that the DMA transfers from the FPGA to your RT target are taking priority of your controller's processor over the serial communication, resulting in a visa buffer overrun. I would recommend taking a look at this knowledgebase article: http://digital.ni.com/public.nsf/websearch/D776A9D834B132AB86256ED2004E18EF?OpenDocument on setting the receive serial buffer size in the Measurement and Automation Explorer. You can also take a look at this knowledgebase article: http://digital.ni.com/public.nsf/websearch/2D5F972CD550BBC386256F0B005E9A63?OpenDocument for more background information concerning this issue. Hopefully this helps!
01-19-2007 03:50 AM
01-19-2007 10:09 AM
Hi julesjay,
Hmm, it would appear that we could be looking at a bug in NI-Serial here. In order to file a corrective action request to submit to R&D regarding this matter, I will need to reproduce the problem on my end first. I was wondering if you could tell me what version of LabVIEW FPGA and what LabVIEW FPGA module you are working with, and if there is anything else specific to your set-up that you think would help me to replicate your system. Thanks!
01-19-2007 10:35 AM
01-22-2007 02:18 AM
