08-04-2014 08:48 AM
hi everyone
I'm trying to plot a graph of voltage
Why this error?
Thank you very much
08-04-2014 09:02 AM
I guess you are simply using the reference control for waveform chart instead of creating waveform chart reference. Did you take this code through a snippet? Ok, right click the waveform chart Create>Reference then wire this reference to the property nodes.
08-04-2014 09:15 AM
I'm not going to go into why you get an error.
I am going to ask you what you were thinking! What were you thinking?
You wired a value to the terminal then created a write value property node to the same terminal......... Don't do that its a waste of BD space! really the terminal will write the value just fine.
08-04-2014 09:16 AM
08-04-2014 09:46 AM
Hi everyone, sorry my english..
http://forums.ni.com/t5/LabVIEW/stream-data-from-a-subvi-to-the-main-vi/m-p/2205150/highlight/true#M... >> Anexo >> vi references.zip >> 3 (SUBVI)
I created a sub vi ... I want to show the graphs on main VI and I'm using Control refnum.
