Error -10401 occurred at AI Group Config
Note: more discussion generated from repost over here.  Let's all move over to that thread.
-Kevin P
Message 11 of 29
(1,738 Views)
Yeah, Kevin is right, should have posted here since the begining.
Here's the link: https://www.dropbox.com/s/75dvlpqpcb88aaw/Prog.vi?dl=0
Message 12 of 29
(1,793 Views)
Picking up from Ben & Kevin's hints....
The new motherboard has a new PCI bus and there is likely a registry entry reserving the device enumeration.
Power down, Pull the boards, reboot, clear the MAX config (reset MAX database)
Reboot
Power down
Reinstall the device1
Power up
Power down
Reinstall device 2
Power up
In that order exactly.   You should be golden then.
"Should be" isn't "Is" -Jay
Message 13 of 29
(1,776 Views)
That drop box link is malformed and useless for me.
Zip up the code and attach it to this thread.
The code may give us a clue as to why things have gone south after the mother board was replaced.
Ben
Message 14 of 29
(1,774 Views)
Memory's fuzzy, but here's what else I see in the code that may require some work in MAX:
The calls to "AI Group Config" have both a hardcoded device # *and* a hardcoded set of virtual channels with names like T_1_10, T_1_11, etc. for device #1 and T_2_10, T_2_11, etc. for device #2.
1. It will be necessary that these are defined and configured correctly in MAX.  Hopefully that part's still intact through the motherboard change.
2. I notice consecutive commas in the list of virtual channels for device #2.  It starts "T_2_10,,T_2_11,T_2_12".  Maybe you need to delete the extra one?  (But if that clears things up, then the same code should have been throwing the error with the old motherboard.  Which suggests that the source code may have been changed.)
-Kevin P
Message 15 of 29
(1,793 Views)
Wait!!!  Don't follow Jeff's advice to reset the MAX database, at least not *yet*!
As I just mentioned in my last msg, the code depends on a bunch of virtual channels whose definitions would be lost with a MAX database reset.  At the moment, it's not yet clear to me that you *need* a MAX database reset and it may well be harmful.
(Note: such a reset is often good advice.  Maybe not this time though).
-Kevin P
Message 16 of 29
(1,788 Views)
Message 17 of 29
(1,786 Views)
-Kevin P
I have been burned by Virtual channels in MAX that either were lost or not supported with LV upgrades. I avoid them like the plague now and do most of my IO config using fist principles and never mess with setting thing up in MAX. Much too fragile.
We could be fiddling with MAX for a long time until it is all set-up correctly.
Bad Joke time!
Spoiler
Configurations in MAX and unreliable third party hardware device sooner or latter we have to fiddle with thing to get it working. I have a code term I use when reporting to my better half;
Fe Fi Fiddly IO
(my apologies to Stephan Foster)
Groans are expected.
Ben
Message 18 of 29
(1,785 Views)
Speaking of channels...
Message 19 of 29
(1,777 Views)
Yes, Kevin is correct about hard-coded virtual channels.
The device ID's of those two boards should be 1 and 2 (not 15).
The syntax is weird but it looks like only two channels used on each device.
Ben
Message 20 of 29
(1,774 Views)
