10-14-2007 11:32 PM
10-16-2007 06:27 AM
Hi Christian,
Please look at those two links, they might help you to solve the problem:
http://digital.ni.com/public.nsf/allkb/AAFE6EE59FEEB7DF86256EB300614604?OpenDocument
http://digital.ni.com/public.nsf/allkb/C8799092975EF5DC862565ED004EF7BB?OpenDocument
Regards
02-18-2021 02:31 AM
I also encounter the same problem.. Please help to solve this problem.
02-18-2021 02:43 AM - edited 02-18-2021 02:45 AM
Hi manifsg,
you still use a device with this old TraditionalDAQ driver in 2021?
Mind to provide more information on the whole DAQ system?
Upgrade your setup to use DAQmx instead…
(Maybe it helps to replace the corrupt configuration file with a "known working" version taken from a backup of your DAQ software?)
02-18-2021 02:56 AM
Hi GerdW,
My company still using window 98 and XP to run labview 5.1 !!
DAQ system version is 6.6.
Another system working fine no issue.
Kindly refer both attachments.
02-18-2021 03:04 AM
Hi manifsg,
Oh dear…
@manifsg87 wrote:
Another system working fine no issue. Kindly refer both attachments.
What should I do with those images?
What about the suggestion in my last message?
02-18-2021 05:13 PM
Hi GerdW,
Still seeking advice from Expert by using the current system.
Impossible for my company to afford to spend money on an upgrade DAQmx system
02-19-2021 01:36 AM - edited 02-19-2021 01:38 AM
Hi manifsg,
You are working with an OS going out of support 15 years ago.
You are working with a LabVIEW version decrecated since >20 years.
You are working with TraditionalDAQ driver which was replaced by DAQmx 18 years ago.
You are asking for help which only can given when having (physical) access to your DAQ system and complete source code.
Solution: Spend money on hiring a local expert to do your work of keeping this system running. There is a "Job openings" forum in this community…
I still propose the solution to spend money to replace this system by a modern version using modern components and modern software!
So your company don't want to spend any money and you want to get solutions for free by using this community?
What kind of business is your company involved in? Does your company also don't pay their suppliers?
