Error 1003 occurred at Invoke Node
Ok Nickels&dimes i got it, only for future readers i solved this case making all this VIs included onto .exe files and they are called by the system exec and each call from a first Vi with a root of case structures called by own booleans... excuse for posting 6 years later!
Message 11 of 13
(596 Views)
@margasan wrote:
you may wanto to check this link too..
How Can I Call a VI Dynamically from an Executable Without Including Those VIs in the Build?
I know this thread is old, but when I tried to open the KB article, it says...
Error
You are not authorized to view this document
Could someone post the working link here?!
- Partha ( CLD until Oct 2024 🙂 )
Message 12 of 13
(579 Views)
Hey Pathabe,
We took that link offline because we recommend including the VIs in the build. This is because LabVIEW searches through your hard drive and aggregates all functions and subVIs to one location. With just the LabVIEW Run-Time Engine, you must have the same dependencies as the development machine.
If you must do so, you can try the following:
  • Control the dependency of the subVI by moving it to the desired folder, and then loading the VI into LabVIEW ('Select a VI...' on the functions palette)
  • Build a source distribution
I recommend making a new post if you have any issues with the above.
Bdog
Message 13 of 13
(571 Views)
