11-18-2016 12:28 PM
I am attempting to install the DAQmx 16.1.0 drivers onto my Windows 10 desktop running Labview 2016. If I click to install the download, I get an error that reads :
The application was unable to start correctly (0xc0000018). Click OK to close the application.
I have tried running the program as administrator, but then it brings up the " do you want this program to make changes to your device" message, I hit yes, then it goes away and the cursor turns for second and then nothing happens.
I'd like to know what I can do to install DAQmx drivers. I have also reinstalled Labview to no avail. In another thread someone said they used the update service to install it, but I see no way in which I can install the drivers through that service. Any help would be appreciated.
11-21-2016 02:41 PM
Have you tried downloading a different version of NI-DAQmx such as 16.0.0? It is also compatible with your Operating System and version of LabVIEW. (http://www.ni.com/download/ni-daqmx-16.0/6120/en/)
*Just run the NI Downloader .EXE file*
Also, the NI Update Service would be the typical way to workaround this but it will only show a new version of NI-DAQmx if you have used previous versions of NI-DAQmx on your machine before.
12-01-2016 09:54 PM
Thanks for your response. I tried downloading the 16.0.0 version and it still provides the same error message.
12-05-2016 09:49 AM
Try the following steps:
regedit
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\WindowsNT\CurrentVersion\Windows
APPINIT_DLLS
and delete the default valueI found a forum where this worked for another user.
12-07-2016 03:35 PM
I'm running Windows 10 and the latest version of LabView 2016 and I was getting your same error with 16.1 and 16.0, but the version before those two (15.5.1) worked. After installing DAQmx 15.5.1 the DAQ Assistant was present instead of there being the blank spot.
12-07-2016 03:52 PM
My mistake, I saw the wrong icon. The DAQ Assistant is still missing after installing DAQmx 15.5.1, sorry about that.
12-07-2016 07:32 PM
Solved it - installed 15.5.1, then checked for updates through LabView's help menu and selected 16.0.0, now that driver was able to install correctly and the DAQ Assistant is present.
12-25-2016 08:45 PM
Thank you for your efforts on all fronts!
Tom
04-03-2017 06:41 PM
Thanks so much!!! it worked for me!
05-24-2017 09:50 AM
Another option which worked for me with 16.1.0. I just opened the exe using 7zip and extracted the files then run the setup.exe directly from there and it worked fine. (windows 10)
