Error 0xBFFF003A with viEnableEvent
I would like to read data from a USB RAW device but when I try to enable the interrupt with viEnableEvent I get the error code: 0xBFFF003A - Unable to start operation because setup is invalid (usually due to attributes being set to an inconsistent state). I'm using this sample code:
status = viOpen (defaultRM, "USB0::0x413c::0x3010::NI-VISA-0::RAW",VI_NULL, VI_NULL, &instr);
if (status < VI_SUCCESS)  {
printf ("Cannot open a session to the device.\n");
goto Close;
printf("Enabling USB Event\n");
status = viInstallHandler (instr, VI_EVENT_USB_INTR, usbHndlr,0);
status = viEnableEvent (instr, VI_EVENT_USB_INTR, VI_HNDLR, VI_NULL);
My OS is XP SP2 and I use CVI 7.0 / NI-VISA 3.6. The .inf file to install the USB device was created with DDW. Any clue about this problem? Is there any other way to read data from USB RAW device?
Thanks.
(2,515 Views)
Gullit,
communicating with devices using USB RAW Visa mode is documented on the following KB page
http://digital.ni.com/public.nsf/websearch/E3A2C4FE42D7ED0D86256DB7005C65C9?OpenDocument
There is also an example that shows how to program USB RAW devices using VC#.NET. Function calls are similar to the ones you should use in CVI, so it may be helpful
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=F3A25808D07C033AE0340003BA7CCD71&p_...
Hope this Helps,
AlessioD
(2,504 Views)
