Error 0xBFF60493 with prosillica firewire camera
I am getting a  Error 0xBFF60493 with prosillica firewire camera with measurement & automation explorer. What is the solution
Message 1 of 9
(3,758 Views)
Hi Zepp,
Can you confirm if this is on your Windows system or a CVS.  If it is a CVS then you may want to look at this forum: http://forums.ni.com/t5/Machine-Vision/Why-do-I-get-Error-0xBFF60493-when-snapping-a-color-Image-fro....
Cheers,
James Mc
Ask me about Rust & NI Hardware
My writings are at https://www.wiresmithtech.com/devs/
Message 2 of 9
(3,731 Views)
Hi it is a windows 7 machine
Message 3 of 9
(3,729 Views)
Hi zepp2,
What model of camera is it and what mode is MAX set to?  Can you send a screenshot of your MAX set up?  This allows us to check if the settings you have are valid for the camera.
James Mc
Message 4 of 9
(3,717 Views)
Hi
The Camera is a EC650. NI.pngI have it working on other machines.
Message 5 of 9
(3,714 Views)
Hi any ideas on this?
Message 6 of 9
(3,691 Views)
Hi
I have tried re-installing Labview drivers but this has not solved the issue. any ideas
Message 7 of 9
(3,681 Views)
Hi Zepp,
Whats the actual error message that you get from MAX?  In LabVIEW this error is Invalid Video Mode, and normally this would be the same in MAX.  However from your screenshot it does all seem to be set to correct format for the camera and these modes have been tested by our vision team with that camera.
You mentioned this works on other systems.  Is anything different?  Im thinking driver versions, firewire cards, settings. Try saving your settings for the camera on the working PC and transferring it to the new one (right click on the camera and select save).
James Mc
Message 8 of 9
(3,663 Views)
Hi Zepp,
Have you been able to compare your two systems to work out what the difference was?
James Mc
Message 9 of 9
(3,645 Views)
