02-28-2018 01:13 PM
I am having trouble running the host file on the cRIO. I have checked the firewall settings, redeployed the project, reconnected all variables that display the error and have updated the programs on the computer. Also following this guide
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000PAinSAG
I have looked at cause 1,3 and 4. This program works fine on the first cRIO and when moved to a second computer and cRIO the error 0x8BBB0005 shows up every time. Also the display was showing strange readings of voltages during one of the attempts. After stopping and restarting it displayed the -50400 error.
03-01-2018 04:31 PM
Hi Lbaxter,
Could you re-post the link to that article or perhaps the title? When I follow your link I get a Page Is Not Found error.
Since it seems there might be an issue with the firewall, have you tried these steps while disabling all firewall and antivirus programs? That would allow you to narrow down if that is the source of your issue.
03-05-2018 03:00 PM
03-06-2018 11:49 AM
Have you tried disabling the firewall like I mentioned to see if it helps with your issue?
Also, the -50400 error you mentioned is a timeout error. Have you tried increasing the timeout value?
