01-27-2022 03:30 AM
Izin bertanya masters, untuk equiment ini ambilnya darimana ya? dan kegunaannya apa?
terimakasih banyak, saya baru menggunakan labview, mohon bimbingannya
saya menggunakan labview 2012
Solved! Go to Solution.
01-27-2022 08:40 AM
Hi dinsul,
@brighti wrote:
Permission to ask masters, where did you get this equipment from? and what use?
thank you very much, i'm new to using labview, please guide
i use labview 2012
It's a string-to-number conversion function! Look for it in the string->"Number/string conversion" function palette and read the context help for that function…
01-31-2022 10:34 PM
I'm new into Labview and I can't find this equipment, can someone tell me where I can get this please?
I'm using labview 2012
01-31-2022 10:53 PM
Dear masters, please help me how to connect the equal comparison to subtract. I'm trying to do like the first pict but always error like the second pict
thankyou
01-31-2022 10:56 PM
Thank you so much, it's really help me. But can you please tell me where can I get this equiment?
02-01-2022 01:45 AM - edited 02-01-2022 01:52 AM
Hi dinsul,
You really should take the Training resources as offered at the top of the LabVIEW board. Really!
This is a boolean (see that "TF"!?) indicator (see that triangle at the left side!?) terminal (set to icon view, which I don't like)!
EDIT:
I merged your threads as you basically ask on guidance to actually learn LabVIEW! See my comment above on Training resources…
You cannot subtract a float from a boolean value as you can read in the context help when hovering the mouse over the broken wire. (Again: do the Training courses!) In your blurry image at the left border there probably is a multiply instead of an equal function…
