I have an old DAQ card (DAQcard AI-16XE-50) and I am trying to get an encoder input into labview 8.6. Encoder output is X4 / quadrature.
I did the DAQ part successfully, using two digital line read functions, but my loop runs at 10ms. So if my shaft rotates too quickly, I loose pulses and the angle reading is wrong.
On the other hand, on DAQmx if I use a simple DAQ assistant no matter how slow I run my loop which asks for the reading from the DAQ assistant, the DAQ assistant output is perfect. I am assuming without me coding it to do so, it continuously tracks the pulses from the encoder and 'knows' the angle value, but I ask it to reveal it to me once every 10ms only.
Could anyone help me emulate this DAQ assistant performance (behind-the-scenes reading of an encoder independent of loop time) using the traditional DAQ pallete available in labview 8.6 and maybe some nested loops and logic? I tried looking at the guts of the DAQmx thing but I couldn't figure it out.
Alternatively, If I have no option but to buy a newer laptop USB DAQ system, please let me know.
Any help is greatly appreciated,
Sincerely,
Hasan P
