To return to the OP's oeiginal query, and assuming that te elapsed time VI is used.
Rather than trying to extract specific bits of a string, which will vary depending on the PC setup, if you want to retrieve specific parts of the data/time...
Use the double Present (s) output, make it into a time stamp with "to time stamp", then "seconds to date/time" to comvert into a cluster containing each of the components. Extract from the cluster as required.
I'm putting all of the info into a document at the end which can be checked by another person and they're comparing my data to the data taken by another independent sensor so we need times that can be eaily compaired. Present absolute is in seconds since an abritrary amount of time so it's not as easy to compare with as present time.
