Elapsed Time VI Present Time String to Elements
Hi All,
I want to get the string "7/28/2011 3:31:18 PM" as is from the Elapsed Time VI Present Time Setting into an Array that I'm using as a write-out file.  I tried using the "Scan From String" function but I can't seem to get the right Format String.  I found the "Syntax elements" but they seem to use different combos then the example given for time in the "Scan From String" function help box.
Thank you for your help,
Falcon9a
Message 1 of 14
(3,169 Views)
Hi Falcon,
that should give you a kick:
Btw.: that doesn't seem to recognize the AM/PM flag - at least on my German WinXP. So someone else may shed some light on this. But: Who uses 12hour time format string for scientific data?
Message 2 of 14
(3,166 Views)
@GerdW wrote:
Hi Falcon,
Try thisSmiley Wink
the Indicator is set for system time format- and those darn AM PM flags a system dependant-  better to just let the system setting work for us rather than fight them.
"Should be" isn't "Is" -Jay
Message 3 of 14
(3,161 Views)
Hi Jeff,
"better to just let the system setting work for us"
Well, this will only work in the US...
Message 4 of 14
(3,149 Views)
A drill through the format strings help will eventually get to the table of the time strings. In a footnote, it says,,,
  • You cannot use <%H> (24-hour clock) and <%p> (AM/PM flag) together in the same time format string. If you use <%I> (12-hour clock) instead of <%H>, <%p> operates properly
So,,   Use %I (In phonetic alphabet that's upper case India) instead of %H
One route to the help page is via the Help Contents
VI and function reference --> String Functions --> Format Codes for the Time Format String
Rod
Message 5 of 14
(3,138 Views)
@GerdW wrote:
Hi Jeff,
Not quite Smiley Wink the Elapsed Time vi. (if you care to drill through the vi) returns "Present Text" as string from a Format date/ time primative with the default (%c) format.  %c is equall to %<%x %X>T universally! Even in Germany!
Note: I forgot about %c...  but who likes to write "c" in  LabVIEW anyway?Smiley Very HappySmiley Very HappySmiley Very Happy
Message 6 of 14
(3,129 Views)
Cool, that seem perfect, but now how do I turn the red line into an orange one?
Thank you,
Falcon9a
Message 7 of 14
(3,119 Views)
Perhaps. But (at least in LV2009) %x %X and %c LOCALE-SPECIFIC.
Thus on my system, 29/7/2011 02:03:04 AM and 29/7/2011 02:03:04 PM (using %c format) both refer to the early morning today 29/07/2011. The AM or PM is not scanned/ignored as the format has been satisfied after the "04"
Rod (in the UK)
EDIT: Using format date/time string, with format "%c" is is now a little after 29/07/2011 14:39:32
Message 8 of 14
(3,118 Views)
Rod (in the UK)
did you start with the output from "present text" out of Elapsed Time vi on your pc or the litteral text from the OP? What are your local specific settings (24 hr clock maybe?  "14:39:32")
Message 9 of 14
(3,111 Views)
I've just tried again.
New VI. Drop an elapsed time.vi.
Right click on the present text output. Create indicator
Run the Vi.
I get 29/07/2011 14:56:00
I have my locale set to English (United Kingdom)
Thus the standard settings of dd/mm/yyyy HH:MM:SS (24 hour clock) are in effect.
Rod
Message 10 of 14
(3,095 Views)
