You haven't posted any code (and if you do post, please attach the VI, not a picture of the Block Diagram, unless, of course, it is a LabVIEW Snippet), so I'm unsure how you are doing this. Are you using Find Systems using cRIO as the Device Class? Why do you need to specify which of your PC's NICs to use?
