This snippet will turn on codes display for all string controls in a VI. It will try to cast everything into strings but I just clear the error and move on.
NOTE: I would not run this on your working copy unless you have a backup. Just sayin'.....
aputman ------------------ Heads up! NI has moved LabVIEW to a mandatory SaaS subscription policy, along with a big price increase. Make your voice heard.
If you are mucking with the display style, make sure to make the display style visible. Many issues can be quickly figured out with that turned on.
There are only two ways to tell somebody thanks: Kudos and Marked Solutions Unofficial Forum Rules and Guidelines "Not that we are sufficient in ourselves to claim anything as coming from us, but our sufficiency is from God" - 2 Corinthians 3:5
