Editing contents of a labview array
Hi all,
sorry I am new here. I have an array I of indices and an array A of zeros, both integer valued. I am looking for a way to increment by one the elements of A that corresponds to the indices in I. In python for example it would be:
for i in range(0, len(A)-1):
    A[I[i]] += 1
or in C:
 for( i = 0; i < sizeof(I)/sizeof(I[0]); i++ ) {
    A[ I[i] ]++;
or in Matlab:
for ii = 1:numel(I)
    A(I(ii)) = A(I(ii))+1;
end
So far I made use of a for loop and then I use a) a "In place element" structure with a Index/replace function or b) a "Replace array subset" function, and a postincrement function:Clipboard.png
The problem is, in both cases the output just keep in memory the last change, i.e. if
A = [0 1 2]
I = [0 0 1]
I would expect as an output:
[2 2 2]
while what I get is:
[0 2 2]
I hope I state the problem in a clear way. Sorry again I am new to this community. I tried to search for a solution but I guess I am missing something more fundamental here. Any help would be greatly apprciated
Best,
M
(5,547 Views)
Accepted by mlgpzz
The fundamental thing you're missing are shift registers. Use these to store values between loop iterations. Otherwise you keep modifying the original array in each iteration.
(5,536 Views)
thanks a lot dan_u
indeed, replacing with shift register does the job
Any idea which one of the two solutions I listed in the first post is the most efficient?
Best,
M
(5,515 Views)
As previously stated, you just need a shift register.
Also, you do not need to wire up the N on the FOR loop.  The reason is because the loop known how many iterations to perform based on the Autoindexing array.
(5,512 Views)
With the latest compiler, I am fairly certain it turns out to be the same machine code.  So then it just becomes a matter of readability.  Personally, I find the In Place Element Structure to be easier to look at.
(5,508 Views)
Dan is correct.
Also you don't need to connect the "N" input.
The "indicies" array is set to auto-index.
Founding (and only) member of AUITA - the Anti UI Thread Association.
(5,496 Views)
