Editing a Palette seems to be missing a few options.
So this is odd... I'm attempting to add a library by editing a palette set (by following the directions linked here). However, I seem to be missing a couple of options, namely the ability to edit the palette set... what am I missing?
I've tried "right clicking" all over to see if there are any hidden menus. So far I haven't found any...
I've attached a screen shot here.
Thanks for the help.
(2,279 Views)
When you select Tool->Edit palette it opens the palette in edit-mode. You should now be able to r-click in the palette to insert items. See attached picture.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(2,257 Views)
Accepted by topic author slow
So this is fun... it seems that when Labview is spawning the new windows containing the editible functions... they're being spawned partially off screen.
I think that did it. Thank you.
(2,241 Views)
