zyl7,
the parameters you are looking for are properties from the graph itself. Therefore, you have to look around a bit in the property node from a graph... i am sure you will find out quite quick what i mean.
There are some examples provides with LV, but they are commonly focused on a special control; sadly i havent found one for intensity charts/graphs.... but this
link can help you.
hope this helps,
Norbert B.
Norbert
Expert: Geometry
