Edit>> Disable Panel Grid Alignment does not affect the Positioning of Front Panel Labels
Hi Jeff,
No Luck, I have changed it to Ctrl + [, but still nor working.
Message 11 of 17
(844 Views)
What does CTRL+#  mean, anyway?
I see the next shortcut on my list shows CTRL+SHFT+A.  That I understand.
Does CTRL+#  mean  CTRL+SHFT+3      ?
Because, unless you have a telephone keypad, there is no single key for "#".
Either way, it doesn't work for me on LabVIEW 2012.
Message 12 of 17
(827 Views)
Hi Wildcatherder,
As you guessed in your post CTRL+# does mean CTRL + SHIFT + 3. I was also able to test this functionality in LabVIEW 2012 and this keyboard shortcut did deliver the desired functionality. It is important to note that the front panel and block diagram have separate toggles. To enable or disable grid alignment on the front panel you must have the front panel as the active window in LabVIEW. Using this shortcut with the front panel active will not affect the block diagram grid alignment.
Patrick H | National Instruments | Software Engineer
Message 13 of 17
(807 Views)
At least in 2012: While dragging the label, press spacebar. That will stop the label from snapping to the predetermined positions.
2010 works, too.
Message 14 of 17
(775 Views)
Thank u man
Spoiler
Message 15 of 17
(710 Views)
A good tip, thanks
Message 16 of 17
(579 Views)
FYI
  • The default block diagram grid size is 16 pixels (go to Options>>Block Diagram>>Block Diagram Grid to modify).
  • Shift + arrow key moves selected object one grid unit (16 pixels by default).
  • The arrow key alone moves selected objects one pixel (as you said).
Message 17 of 17
(328 Views)
