Hi i am trying to edit the pulse measurements vi located in Waveform measurements pallette. I only want to measure the pulse width of a single pulse and therfore do not require the period and duty cycle measurements. I think i need to edit the call library function node and then rename so as not to edit the original file.
I can edit the function node but under file, the save as option is greyed out and will only allow me to save under the original name.
Can anyone help in this matter?
Grant
