08-17-2011 09:55 PM
Please suggest.
1. How can I make a password-protected VI ?
2. How can I protect/hide only the bock diagram from others?
3. How can I convert a labVIEW program to an exe/setup program that can run in any computer and does not need to install the LabVIEW full software in that computer.
Mahmud.
Solved! Go to Solution.
08-17-2011 10:20 PM - edited 08-17-2011 10:23 PM
1. File >> VI properties >> Protection >> Password-protected. Be sure you really want to do this, and if you do, write down the password in a safe place. There are many posts on the forum where people are asking for help and can't get any when they can't remember their password.
2. Same as #1. There is a way to remove the block diagram, but it prevents you from ever being able to edit that VI or upgrade to a newer version of LabVIEW unless you save a copy somewhere without the block diagram removed. Just don't do it. http://forums.ni.com/t5/LabVIEW/How-to-hide-block-diagram-without-using-password/m-p/862282/highligh...
3. You need the application builder which is an add-on, or is included with the Professional Development Suite.
08-18-2011 12:21 AM
Help rocks. thanks.
08-18-2011 12:26 AM
Hi
I have academic full version not the professional one. Can I buy application builder seperately if possible. Thanks.
08-18-2011 12:41 AM
08-18-2011 12:26 PM - edited 08-18-2011 12:29 PM
I can make an exe file/setup installer from the Build application. But two more inquiries necessary.
1. How to give the password in exe/setup installer?
2. How can I add an email address in the exe/setup installer to retrive the exe/installer password if forget/requested ?
Thanks in advance.
Mahmud.
08-18-2011 12:56 PM
You don't need a password for an executable. The executable doesn't have any source code that could be looked at that would need to be protected.
Now if you are thinking of using a password to keep unauthorized users from actually using your program, that is a different question. Search the forums, there have been a number of threads discussing passwords as a part of an application and various licensing schemes to prevent people from using your application unless authorized.
08-18-2011 01:42 PM
And check your academic license to see if you are even authorized to use the app builder with it. I know you are prohibited from creating commercial applications so it's pretty hard for me to see how you can justify the cost of the app builder anyway.
08-18-2011 07:06 PM
What is my interest is to avoid any unauthorized person/company to use my full executable file/software without my legal permission or payment.
Is there any option to retrieve the password via email if forgotten?
Thank you in advance.
Mahmud.
N.B: My university already installed professional full version in my computer and it has already Build application section in tools menu.
08-18-2011 07:50 PM
And because of this, there does not appear to be a way to include an installation key with your installer. For internal use, to protect against unwanted access, you could provide a login.
