07-22-2011 08:59 AM
Hi Ppl,
I have an application built in Windows XP Service Pack 3. When we tried running it in Windows 7 station it crashed before opening up the front panel and below is the crash details. However if we built the application in the Windows 7 station itself it works fine. I tried running the application in compatability mode, it didn help. The error message points to a dll in the run time engine. The DLL was located in the correct location as expected.
I'm using LabVIEW-2010 SP
Problem Event Name:APPCRASH
Application Name:Application.exe
Application Version:0.0.0.1
Application Timestamp:4c24e8f5
Fault Module Name:libappweb.dll
Fault Module Version:2.4.0.49156
Fault Module Timestamp:4c212a85
Exception Code:c0000005
Exception Offset:0001ba4c
OS Version:6.1.7600.2.0.0.256.1
Locale ID:16393
Additional Information 1:0a9e
Additional Information 2:0a9e372d3b4ad19135b953a78882e789
Additional Information 3:0a9e
Additional Information 4:0a9e372d3b4ad19135b953a78882e789
Sathish
07-22-2011 09:50 PM
Guys, Any help ? Is this a difficult question ? Should I try NI support to get this solved ?
07-31-2011 11:30 PM
The solution would be in the following links:
http://blogs.technet.com/b/askperf/archive/2008/06/17/to-dep-or-not-to-dep.aspx
http://digital.ni.com/public.nsf/allkb/D12F9263065435DA8625784F006ECFD4?OpenDocument
Please revert back if the problem is not solved.
