08-07-2018 09:52 AM
Hi, i have installed NI-CAN 18.0 on windows 10 and ni 8473s. The hardware is installed correctly, but when i create a message in the channel of ni- max, i have the next error: "Test Panel cannot run since no CAN ports are available. Make sure you have at least one NI CAN card inserted into your computer".
So i have found this link https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000004AgKSAU
, and i have read the installatation guide, but when i try to do the point (4.) of http://download.ni.com/support/softlib//embedded%20networks/CAN/code%20library/CAN/Frame%20Channel%2... i don't find the software that i should install.
can i solve it?
thank you
08-08-2018 12:20 PM
news?
08-22-2018 07:55 AM
Hi soxcarmine,
i guess this article has the answer: https://forums.ni.com/t5/LabVIEW/CAN-8473-Not-working-with-Test-Panel-in-Max/td-p/1893731
The KnowledgeBase you've linked is referred to LV programming, not NI MAX.
