11-05-2012 09:24 PM
Dear All
When I run mathscript node in LabVIEW 8.2 following error occurs. Can you please guide me how to rectify it.
The block diagram is attached for reference.
Best Regards
Muhammad Irfan
11-06-2012 12:30 AM
Looks like you are using an xmath script node instead of a mathscript node. That's not the same.
11-06-2012 12:56 AM
Yes I am using xmath script node because I can not find mathscript node in function pallete (structures).
11-06-2012 01:54 AM
So why do you call it mathscript in the title and in the body of your posts??? 😮
Prior to LabVIEW 9, mathscript was included with LabVIEW. Maybe you did not install it?
