ENABLE in Labview
Highlighted
HELLO
Is there any Vi that resemble to exactly or somehow like enable block in matlab .i want to impliment an enable just like it works in matlab Matlab enable can be seen on following link   (http://www.mathworks.com/access/helpdesk/help/toolbox/simulink/index.html?/access/helpdesk/help/tool...)
anone who can guide me i wan to read values of my signal(array) using enable.
Madd
(2,352 Views)
Highlighted
Hi Madd
There isn't any specific single VI in LabVIEW that implement the same functionality you described. However, it is possible to program the enable behaviour with a few extra VIs.
The following screen capture shows how the enable functionality was implemented using LabVIEW's logical functions and memory blocks present on the LabVIEW Control Design and Simulation Module. The VI on the top left  implements the main functionality and the extra logic (in the red circle) add the extra feature you are looking for.
Hope this helps
Javier Gutierrez
National Instruments Control Design and Simulation
(2,257 Views)
Highlighted
Screenshot is pointing to your local drive, therefore we can't access it ... (which is a good thing!)
(2,243 Views)
Highlighted
Hi smercurio_fc
  You are absolutely right, my fault Smiley Very Happy
Here is image
JavierG
LV Control Design and Simulation
Message Edited by Javier_Gutierrez on 05-05-2008 05:14 PM
(2,202 Views)
Highlighted
Hello
Tnx for ur response but what if someone is using evaluation version having no (LabVIEW Control Design and Simulation Module). who can one
impliment enable then.
COMSIS
(2,094 Views)
Highlighted
Hey Comsis,
The logic functions used to implement the desired functionality are part of the LabVIEW core palette, except for the memory block, which can be replaced with a feedback node. The main point to drive here is that functionality can be implemented. The code shown is just an example.
Aashish M
CEO
TransferFi
www.transferfi.com
(2,042 Views)
Highlighted
Comsis
You can also download the Control Design and Simulation module and evaluate it for free during 30 days. The link for the download is
https://lumen.ni.com/nicif/us/evaltlktcds/content.xhtml
Good luck!
Javier Gutierrez
(1,848 Views)
