ECU management on base of CompactRIO and LabVIEW (Help needed!)
I'm working on a project, and it's the first time with the CRIO and LabVIEW Combo..
Now I already purchased a couple modules. such as the DRIVVEN PFI and ESTTL module.
But now I'm stuck, I made a complete VI, ready to compile towards the CRIO but now I can't read the cranckshaft and camshaft signal into my Digital input module (must say, this is a NI9411 module , not Drivven!).
I have connected two input pins towards the ENGinsig from the EPT SubVI. but I can't get something on my PC screen or out of the PFI module.
Could anyone help me?!
many thanks
PJ
(2,206 Views)
Example of my program!
(2,200 Views)
First of all thanks for your post!
I would first advise you to repost the question in a less general board.
Posting a question like this in the default "LabVIEW" will make it harder to get the right people to help you.
This board (http://forums.ni.com/t5/Real-Time-Measurement-and/bd-p/280) would for example be a more suitable candidate.
Also do not forget to include as much (relevant) information as possible in your post.
Things I have in mind are:
- The actual code you're testing. (project and necessary files)
- The examples your basing your code upon.
- Which modules are placed in which slots? (a MAX Report of yoiur RT target will do the trick for this purpose)
- Which software is installed on your own pc? (a MAX Report of your own system will be fine for this)
To create a MAX Report, please follow these steps:
http://digital.ni.com/public.nsf/allkb/271F252B4EF0A2E0862570E70056A1E4
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(2,165 Views)
