ECU Measurement and Calibration Toolkit on Real Time Target
I have a problem configuring the "ECU Measurement and Calibration Toolkit" on my Real Time PXIe-8840. Following the Manual instructions it said:
When you use a National Instruments PXI controller as a LabVIEW RT system, you can install
a PXI CAN or PXI XNET card and use the ECU M&C Toolkit to develop real-time
applications for CCP or XCP. As with any other NI product for LabVIEW RT, you must
download the ECU M&C Toolkit software to the LabVIEW RT system using the
Remote Systems branch in MAX. For more information, refer to the LabVIEW RT documentation.
But when i select "Add/Remove Software" from my Remote System (PXI) on MAX the software tree that opening does'nt show the ECU Measurement and Calibration Toolkit, so it's impossible to use the library on the PXI Target. Where am I wrong?
Thank you very much,
Francesco
(3,009 Views)
Accepted by FM82
Found the problem: the version of the ECUMC toolkit, the 19.0 does'nt install on RT target, the 18.5 will do.
(2,946 Views)
Observing the exact same problem. I can install 18.5 to PXI but not 19.0. But I need 19.0 because it includes a specific bug fix I need.
SKTheLimit
(2,860 Views)
You need to work on the host PC, try to reinstall the ECUmc whit Real Time support.
(2,839 Views)
