05-09-2007 07:01 PM
I have two questions about the instrument driver provided by NI for Agilent spectrum analyzer E
1. I’d like to set E
2. I want to use the channel power measurement function and find one VI named “agesa Configure CHP Measurement.vi ” have the setting, but I meet two problems here.
I. When I set the channel span >5MHz, there will be an error. The error message is as the following
“Driver Status: (Hex 0xBFFA0010) Invalid value for parameter or property.
Primary Error: (Hex 0xBFFA0010) Invalid value for parameter or property.
Secondary Error: (Hex 0xBFFC0005) Parameter 5 out of range, or error occurred while setting Parameter 5.
Elaboration: CHP Span”
II. Even I set channel span<=5MHz, the CHP Span and CHP Integration BW still don’t work. Does anyone meet the same problem?
Please see the graph ”agesa Configure CHP Measurement.bmp”
05-09-2007 09:57 PM
If you can't find a function in the driver, then you can look up the command in the manual and send it with the agesa Write Instrument Data.vi. This is on the Utility Functions>Instrument I/O palette.
Before you can use the Configure CHP, you might have to first run agesa Configure Measurement.vi and turn measurements on. I don't have the instrument to verify that, though.
05-13-2007 11:15 AM
06-02-2008 01:32 PM
06-03-2008 09:48 AM
Try to import Agilent CVI driver into LV.
Plz see attatch file. [ Chinese ]
