01-12-2010 03:26 PM - edited 01-12-2010 03:28 PM
In LV 2009 it is still not possible to set the number of stacked plots of a chart programmatically. Is there any useable workaround?
Before I start measurement I know how many channels I will acquire – between 1-16.
Before the measurement starts I want the chart to display as many plots as I have charts
I am building exe in the end (in linked thread is proposed some workaround that doesn't work in executables)
My only suggestion so far is to use 16 stacked plots and play with their height and position to hide and show them = not very friendly. Thanks for any suggestion
02-18-2010 05:47 AM
If you somehow manage to execute the program with "overlayed" plot selected (with the number of stacked plots wired to the property node )and then switch back o "stack plots" progrmatically i think you can solve this...
Guru
02-21-2010 10:56 AM
