Mark,
I would appreciate if i could see some code. Would you please email
it to my hotmail address.
John
On Mon, 4 Feb 2002 07:40:27 -0800 (PST), markwysong
wrote:
>There's not really a property node. I've done this before, but it's
>not exactly straight forward. If you stretch the window that shows
>the trace names and colors, you can show more trace names and colors.
>Make sure that this is big enough to handle the max number of traces
>that you'll need.
>Next, in your code, make a property node for the chart. You'll need
>to set all the trace colors to transparent to begin with, then change
>them to a predefined color depending on how many traces you have. You
>do this by using the property node, setting the active plot, then
changing the color (and name, too). Then you just wire the plots to
>the chart, and it should display it. I can show you some of my code
>that performs these functions if need be.
>Mark
