I have a simple question about a labview programming issue. I am trying to modify an NI Example program for demonstrational purposes. I am using the Multi-plot real-time chart example program (link below) from the NI website. I have changed your example for the chart to display the data in the stacked plot mode. How could I modify it to vary the number of traces dynamically. Is this possible? My goal would be to use a series or radio buttons to control viewing 4, 8 or 16 channels, in real time. All of the code and programs I have seen have channel display statically in the begining setup. Is there a property node of the chart that controls this?
To accomplish your goal, the example VI needs to be modified a little bit. I've made one such modification and attached the modified file. I hope it helps. Please note that nothing shows on the Front Panel Until you press one of the control buttons.
