Duplicate Data Copied to Excel
Having a minor issue with exporting my LabVIEW results to excel. I have two thermocouples, labeled inlet and secondary temperature. These data points show up twice, and I am not sure of why. Additionally, I have it programmed so that I get data points every 10 seconds. However, every 10 seconds I get about 2-3 data points for each time stamp. Attached is my Project VI and a screenshot of my excel spreadsheet.
(1,381 Views)
I was able to fix the first problem I had. It was an issue with the thermocouple DAQ. I only needed one of the temperatures to be wired into the build array to be sent off the spreadsheet. When I had both wired, it duplicated the temperature callouts in the spreadsheet.
I still am having the issue where it records the same data point 2-3 times.
(1,352 Views)
I would recommend you to follow proper state machine architecture.
In the Application Init State ....Create a file with Header,
In the Wait state .....Wait for 10s Delay
In the Read State.... Read and Log results  again go to Wait state
Exit when the logging is done.
(1,336 Views)
